dual vs single gang pots
Started by rhdwave, May 21, 2006, 12:40:16 PM
rhdwave
Does anyone know what the difference is between dual and single gang pots? When you would use one over the other? Thanks!
bancika
Dual gang pot is like two pots put together with common axis, so basically it's used whenever you need to control two things with one pot (like for stereo application)
For stereo applications, like simultaneous volume adjustment on two channels, tone adjustment on two channels, etc., a dual-ganged pot is generally necessary.  I say "generally" because there are chips optimized for commercial audio manufacturers where one pot is used to control the adjustment of two channels.  For our needs here, this is much more the exception.
Occasionally, dual-ganged pots are used to compensate in one part of a circuit for adjustments in another.  For example, most of the time when the distortion control on anything is changed, that involves either increasing or decreasing gain, so a volume change will occur along with changes to the sound quality.  A dual-ganged pot could be used to adjust the volume level to compensate for such volume changes, so that one pot gets used to increase gain while the other one turns down volume a bit to offset that.
In some instances, the function being changed may require two resistances to be adjusted simultaneously.  For insance, in a state-variable filter, two resistances are altered to change the cutoff/center frequency of the filter.  The Mutron/Q-Tron uses two optoisolators to replace what is normally dual-ganged pot in order to change those two resistances automatically at the same time, rather than manually.
In general, assuring that the two sections of a dual-ganged, triple or quadruple-ganged (they exist; I have some) pot track each other flawlessly (i.e., when one section is at 43.2k, the other one is also) is hard to do.  For this reason, when you get to high end stereo gear, in those places where dual-ganged pots might normally be used one tends to see rotary switches with 1% resistors instead.  So, the volume control might be a 30-position dual-contact rotary switch instead of a dual-ganged pot.  Of course, if you're going to charge someone $3000 for a preamp, you'll be able to do that and still make a few bucks.
Dual-ganged pots come in slider form as well as rotary, though I'm not sure about trimpot form.  Because of the mechanisms involved, I don't think you can get multi-turn dual-ganged pots, though I may be wrong about that one.
rhdwave
