boss RV-3 repair attempt
Started by choklitlove, June 01, 2006, 06:56:55 PM
choklitlove
i found a RV-3 digital reverb/ delay pedal for $25.  it looked to be in great condition, but it doesn't work.  too good to be true...
anyway, here's what happens: when connected to wall wart or a battery or both, the light is always on even when "switched" via stomp.  although the light is on, there is no effect, but the "balance" knob affects the sound ever-so-slightly.  but no effect.  i thought this might be a switch problem, so i disconnected the two wires from the switch, and touched them together, but this made no difference.  i looked at the main board a little, but being that it's almost all smd and ic's, i hope that's not where the problem is.
GGG has a schematic, so it might help: http://www.generalguitargadgets.com/boss/BossRV-3Combined.gif
anyone have any ideas?  thanks!
oh yeah, aaron: i think a repair (of manufactured stomps) forum would be cool...
my band.                    my DIY page.                    my solo music.
nag hammadi
i have one of those that is broken as well.  what SUCKS is that my bride saved up for a while and bought it for me out of the blue, brand new.
it lasted a month.  that is pretty much what made me swear off mass produced pedals (and later on, amps) until today.
i second the notion for the commercial pedal repair form.
in the face of you all i stand defiant - subhumans
cd
#2
Looking at that schematic, the footswitch tells the computer (the M37470 chip) to do something, which it then passes on to the FET switching.   I would start by checking the voltage on the gate of the each FET - it should change when the switch is depressed.  Going by the schem, they should be alternating - one will be high while the other is low, etc.
