Phozer Caps
Started by Noplasticrobots, May 31, 2006, 01:00:20 PM
Noplasticrobots
I know the standard rule for subbing caps, but just thought I'd ask...
In the Phozer circuit, there are three 1uf polarized caps. I have only one polarized 1uf caps. Is it ok to mix polarized and non polarized capacitors?
If increasing those three caps makes the speed cut in half, what about decreasing them to make it faster? Say to non polarized 0.1 uf caps?
http://www.runoffgroove.com/phozer.html
I love the smell of solder in the morning.
Noplasticrobots
Also, I read that the buffer should be left off when breadboarding-why? (Buffer is the input at J201, correct?) If so, do I just use a 0.1 input cap to the base of the MPSA13?
MartyMart
Halfing the value is perhaps as far as you can go, using 0.1's is ten times less !!
Try .47uf or .68uf poly caps if you have them, you still may get unpredictable speeds
though !
Keep them matched and see what happens ...
MM.
Noplasticrobots
Will do! Thanks Marty.
