Analogue Reverberator
Started by Dave Eason, June 04, 2006, 03:26:49 PM
Dave Eason
Hey Guys,
I was just thinking to myself if it would be possible to build a reverb pedal without mechanical parts or a microprocessor.  I made an audio unit reverb plugin in C++ which just used a 3 tap delay line, with the delays kept really short and mixed together; could you do this with an old bucket brigade chip, with multi tap outputs, using the same principle?  I can't think of any actual analoge reverb devices that haven't either got a spring or plate in, or use firmware on a micro (or other digital system).
Just out of curiosity, can anyone recommend any god places online where you can send them a board layout and they can manufacture a pcb fairly cheaply, and send it back?
cheers,
David
trevize
Yes it can be done, if you can find the panasonic mn3011, a 3328 stage bbd chip with 6 taps.
there's a project of a reverb based on this chip on synthdiy:
http://www.synthdiy.com/files/2003/eti-mn3011reverb.pdf
and the datasheet:
http://www.synthdiy.com/files/2003/MN3011.pdf
MetalGuy
Better try the Femtoverb /in the DSP section/. You'll get 16 effects in one most of the reverbs. Or if you don't want to bother just go for one of these /strange, it was available couple of days ago/:
http://www.bananas.com/productdetail.asp/pid_8330/productname_Behringer-DR100-Digital-Reverb-Pedal
Better yet, the MN3011 has not been in production for several decades, and every single one is precious for repairing anything that was based on them.  In contrast, the Alesis/Wavefront chips ARE still in production, with sufficient quantity to supply all those Chinese/Korean manufacturers banging out those $150 amps with built in effects.
