Thunderchief Question
Started by jimmy54, June 13, 2006, 09:30:58 PM
jimmy54
Hi Fellas,
I was going to build the Thunderchief using the vero layout posted at indyguitarist.
http://www.indyguitarist.com/torchy/amps_emulation/ROG%20Thunderchief/Thunderchief.gif
I was comparing the vero layout with the schematic at runoffgroove (below) to see what the external wires are that are not marked on the vero layout.
http://www.runoffgroove.com/thunderchief.html
Is there an error in the layout around the 470K and 1K resistors near to Q2?  On the schematic the 470K resistor is in parallel with the 470p cap.  On the vero layout it looks like the 470k resistor is one strip too high and the 1K resistor one strip too low.  Can anyone verify this?
B Tremblay
Looks like that if you simply switch the labels for the 1k and 470k, everything will be correct there.
B Tremblay
runoffgroove.com
jimmy54
Doh, why didn't I think of that.  Thanks Tremblay
