ROG splitter blend blown cap on 18v?
Started by any, June 23, 2006, 06:11:17 AM
any
Hi all,
I just completed a ROG splitter blend and it was working just fine...
But when I tried it with a 18v wallwart I blew the 47uF cap wich was rated 35 volt.
Is there a good explanation for this happening? are more components potentially damaged?
All caps I used were above 18 volt rating, so I'm kind of confused...
Help or explanation would be greatly apprieciated!
ANY
It's supposed to sound that way.
Gringo
Unregulated wallwarts tend to put out quite higher voltages than specified. That would explain your cap frying.
Cut it large, and smash it into place with a hammer.
http://gringo.webhop.net
any
So is there a good chance I fried my TL072 IC's as well?
I'll replace the cap this evening, but is there a possibility other components are shot?
I could clearly see the cap blown off, but I hope thats the only thing that needs to be replaced...
Paul Perry (Frostwave)
Well, the TL072 has a max supply range of 36 volts.
Incidentally, if the input was 18v AC exactly, that gives 18 times 1.4 = 25 V rectified. Less a volt for the diode say. But as Gringo says, it might be putting out a lot more than 18.
just in case, check whether the blown cap was the right way around. (well, I know that I've had a reversed filter cap hold up for a day or so... and then... :icon_eek: :icon_redface: )
any
I've put in a new cap and it runs like it did before on 9 volts, the IC's were fine.
I put a Dunlop 18v DC power supply on it for testing, but I guess I should have measured the output first.
Especially becuase my other 18 volt wart put out 24 volts when I measured it.
The cap was orientated correctly, still don't see how a 35v rated cap would blow in that circuit... even running at 24 volts.
Would their be any advantage in running it at 18 volts anyway?
I intend to use it for bass guitar, so I thought it would give a bit more headroom.
I allready used TL072IP's so maybe 9 volts will do just fine...
