how do i mix capacitors?
Started by jonathan perez, July 11, 2006, 01:45:45 PM
jonathan perez
how do i create a .012 capacitor?
Seljer
When you connecting capacitors in parallel the values add up (like connecting resistors in series).
C = C1 + C2
When you connect them in series you get the same thing as if you were to connect resistors in parallel
1/C = 1/C1 + 1/C2
bancika
place two 0.022 in series and you'll be in the ballpark, within tolerance
jonathan perez
ok, thatll work...how about .09?
Seljer
Quote from: thebattleofmidway on July 11, 2006, 01:56:48 PM
connecting a 1uf and a 0.1uF in series is close (but that 1uF may be pretty big...). Connecting 2 0.047uF in parallel is pretty close.
jonathan perez
PERFECT!!!
how about a .010?
im getting really close to a specific tone...
Seljer
0.010 is a pretty standard value that should be available
jonathan perez
i cant seem to find it anywhere. ill keep looking.
AL
Quotecant seem to find it anywhere. ill keep looking.
You're probably looking for a 0.010uf instead of a .01uf cap. Look for a .01uf.
These are very common and even *gasp* Radio Shack should have them.
AL
jonathan perez
the rat shack in my part of town went under. they were down the street, too.
Gilles C
Also, don't forget that .010 uF is the same as 10nF
Gilles
lacto
That depends on what material caps you are using. For polystyrene you can get a .01uf and a .002 uf to make .012uf. For polypropylene and certain film caps you would have to use a .01uf and (2) .001uf's. This is probably for the sweep cap in a wah right?
