3PDT drilling template
Started by lldrew, July 12, 2006, 02:12:04 PM
lldrew
anybody have a drilling template for one of the taiwaneese blue 3pdt switches?  Something along the lines of the geofex enclosure drilling template?  They have ones for the pots, jacks, and x-wing switches but not for the 3pdt switch.
cd
The 3PDT uses the same 1/2" hole as the x-wing, and is a hair wider but shorter.  The same template should work.
mikey
A better fit for 3PDT switches is 15/32" .. just a hair under 1/2".  Of course if you dont have a 15/32" bit a 1/2" will work just fine.
  I laid the switch on it's sides, and marked the Widths, made a rectangle and drew an X, across center from the 4 corners. Template. Cut a hole for the switch to stick through if you want to double check exactness.
powerplayj
same size as the DC jack I believe...assuming you get the round plastic barrel jack like at Small Bear
builds completed: boutique fuzz, rangemaster, BSIAB2, PT-80, Tonepad wah, Ross Comp, Axis Fuzz, MOSFET boost, Thunderchief, Big Muff (triangle), Mr. EQ, Dr. Boogey,  Neovibe, Dist+, EA Tremelo, ADA Flanger, RM Octavia
next build(s): ???
