pics
Started by Crawf, July 30, 2006, 03:15:35 PM
Crawf
Hi, How do i attach photos to a message, i just cant figure it out, Crawf :icon_redface:
The Tone God
The function is your friend. Under "posting" there is "SMF Bulletin Board Code" which tells you about that little you see when posting.
You will need a publicly accessible host to to store the image.
And I think this is lounge fodder. Also there is a test forum for trying these types of things.
Andrew
QSQCaito
I find the easiest way going to ImageShack.us very easy to upload a pic. Then you copy the link you click on the "Insert Image"   button, paste the link and voila. c'est fini :P(the only words i know in french, lol)
Bye bye
hope it helps
DAC
D.A.C
Crawf
Thanks,Here goes,
Hi,Just thought i`d share some of my builds, at least how i`ve chosen to finish them, apart from the Rat the smaller pedals are in boxes from Maplins here in the UK which have a grey hammerite type finish on them so as i`m no artist these are perfect for me. I bought some sheets of A4 size self adhesive clear vinyl paper which accepts ink from an inkjet printer,so design your logo, print ,cut it out and stick it on, and if required used a clear laquer to seal it, anyway hope you like them, cheers Crawf.
Left to right:-BSIAB,Rocket Fuzz,AMZ Mosfet Boost,Tonepad TubeScreamer,Orange Squeezer and in the middle GGG Rodent.
http://img72.imageshack.us/img72/1636/mypedalsfk4.jpg
QSQCaito
Instead of using the insert hyperlink: Use the insert image:,  And paste your link as you did with the Hyperlink. It should end something like these: [ img ]http://img72.imageshack.us/img72/1636/mypedalsfk4.jpg[ /img ]
and the finale result will be these:
Hope it helps, bye bye !
dAC
D.A.C
The Tone God
Nice Rat Fink!
Andrew
Crawf
Thanks i`ll try that in the future,Crawf.
Sweetalk
Do you see the LED right?... I thought sometimes to put it in that position but I wasn't quite sure of the results... Nice buildings!!!
Crawf
Hi Sweetalk,Yes i can see the LED`s no problem especially as some have ultra bright LED`s. I positioned them there because as a relative new builder i wanted to make it as easy as possible for myself as it`s quite tight in some of the smaller boxes so the LED to the side seemed like a good idea and i`ve just kept it that way, hope this helps, Crawf :)
