what output transformer is used in the Cream Machine by Hughes and Kettner?
Started by Dr Ron, August 05, 2006, 02:19:19 PM
Dr Ron
Does anyone know what speaker output transformer is used in the Cream Machine by Hughes and Kettner?
Connoisseur of Distortion
i don't know anything about this, but isn't that a pedal? if so, i don't think you'd want an OT...
The Cream Machine and Blues Masters are both 1/2 width one rack-unit high boxes. They were available with a set of holders to let you bolt them into a 19" relay rack. They're not pedals.
In reality, they are small tube amps. One does about a watt, the other is a about 3W. I believe the CM is the 3W.
They have a batch of opamp stages and two tubes in each one. One of the tubes is a preamp, the other is used as a power tube. There is a functioning output transformer in each of them. The tubes are run at high voltage. They sound good.
They are set up as either practice amps or mini-amps to run into a mixing board. There is a speaker output on each, as well as a speaker sim and line output.
The transformers are custom made for the units, not commercially available.
