Easy Vibe not so easy. Will these work for the LED/LDR assemblies?
Started by skiraly017, August 03, 2006, 05:36:11 PM
skiraly017
Finished my Easy Vibe last night. It didn't work right away but I'm not ready to give up just yet. After reading what I think were all the trouble shooting threads I think I have some ideas as to what the problem(s) might be. While reading the threads, someone pointed out these as a possibility for use as the LED/LDR assemblies. Any thoughts? Thanks.
Big Red
damn those are cheap. curse my loyalty to Smallbear :D
I'm working on a easyvibe right now too, but I used the recommend leds and photocells from smallbear.
I'm just waiting for my switch to come in so I can box it up and try it out.
I hope you get yours working. let me know how it turns out!
Torchy
I used those on mine (and on the Tremulus Lune). Worked just fine.
RedHouse
I've used them on a univibe (not easyvibe) and they work great.
I used a X-acto knife and cut them in two, they separate easily and the LDR is quite useful w/o the LED.
GibsonGM
What's the problem, Skiraly? What is (or isn't) happening with the EV?  I used the smallbear recommended LDRs and LED's, just stuck 'em together with some wire insulation as a tube.
Does your oscillator work at all?   I learned quite a bit about debugging that baby when I made mine, LOL
skiraly017
Quote from: GibsonGM on August 03, 2006, 09:15:28 PM
I didn't want to say anything until I had exhausted all my possibilities (read "I swear I used the SEARCH function").
1) Very faint sound when pedal is engaged.
2) Center 4 LED's aren't lighting.
3) Loud pop in the chorus/vibe switch.
I'm not giving up, just thinking things through.
GibsonGM
Did you use the same LED's in the power biasing section as in the filter sections?
Perfboard or do you have a PCB?  I'd re-check my component orientation, too, esp. diodes and stuff....you'll get it  ;)
