Trem Lune update
Started by jimbob, August 06, 2006, 12:20:34 PM
jimbob
OK. I finally got around to putting togather my Trem Lune (thanks to $uperpume-great job on the board !!!) and it sounds as great as all the build reports. Its a lot more versitle than my EA trem. The only thing is that my lfo led never goes off even when the effect is turned off. Anyone else have this issue? And how to fix it?
"I think somebody should come up with a way to breed a very large shrimp. That way, you could ride him, then after you camped at night, you could eat him. How about it, science?"
Seljer
with a 3DPT switch, set up 2 parts of it for the regular bypass buisness, and use the 3rd part to connect/disconnect the lfo LED out of the circuit (so its both the indicator led and it shows the lfo's speed)
