Question about connecting soldered points..
Started by guyg, August 06, 2006, 03:30:24 PM
guyg
I soldered all the parts into a PCB, I conneced them all using all the caps and resistors legs I cut off during the soldering..
I just found that it's not a good Idea... is it? any chance it will work anyway?
Thanks :S
p.s
Is there any other way to connect the soldered points except taking little wires between them?
  Not sure I understand this.
  If the connections follow the schematic and all the values are correct [and nothing else goes wrong] it has to work.
Thanks :S
p.s
  PCB means 'printed circuit board'...so the traces on the bottom of the board, the 'artwork' is what interconnects all the parts/pieces...
  *IIUC you've added wires to the existing traces on the bottom of the board?
guyg
Here is the picture, sorry for the bad quality..
It's the soldering and the connecting wires.
QSQCaito
cant' see that pic, at least me.. got a link to it??
bye
DAC
D.A.C
GibsonGM
That PCB looks like the generic type, known as 'perf board'...if so (all little holes, none connected), then your approach should be fine.....provided all connections are mechanically secure and well-soldered!   I do stuff that way all the time, it's called 'point to point', or PTP.     Like said above, this is ok as long as parts are connected right and are the right values.....
Gilles C
Quote from: guyg on August 06, 2006, 03:30:24 PM
Thanks :S
p.s
You mean you soldered the components on a perfboard and used the caps and the resistors legs instead of wire to connects the legs of the parts that needed to be connected together. It's ok. But you can also bend the legs of the caps and resistor under the perfboard without cutting them first. You cut them if they're too long once connected to the other parts.
Like this.
But I don't use perfboards very often. You should try stripboards someday.
Gilles
Connoisseur of Distortion
you acted exactly as you should. with perfboard, you use leads to connect all of the parts. that's the only way, aside from placing the leads close enough to solder one part to the next!  ;)
