Tube Cricket Schematic
Started by dano12, August 21, 2006, 11:12:24 AM
dano12
I've been tinkering with extending the Noisy Cricket amp with a full three-knob tone stack (most likely the classic Fender circuit). Given the loss of the tone stack, I'll need some gain recovery. A good friend shared his tube-preamp design with me and I've worked that into the front end of the circuit.
Before this goes on to the breadboard, any obvious problems or comments?
Peter Snowberg
R5 is unnecessary, the ground of the LED does not need to be switched (so you can use a SPST for power), there should be a cap in series with pins 1 and 8 of the 386 (see the datasheet), and I question the value of C5 (seems a little small) but that's just a guess.
Build away! Everything seems to be there. :icon_biggrin:
Be sure to try out a bunch of different tubes in there. The differences can be startling. I did find that I liked the tone of tubes with larger plate structures more, especially when running at low voltage.
Eschew paradigm obfuscation
dano12
Quote from: Peter Snowberg on August 21, 2006, 12:17:32 PM
Thanks much. I've updated the schematic.
A few questions: first, I've never been able to hear any difference in the LM386 with or without the cap in the gain loop. Any ideas why it is recommended?
Second, what you suggest as a good starting value for the 330pf cap?
mjones99
the first stage cathode bypass capacitor is one of the most important tone shaping elements in a tube amp, typically that value goes from .68uf to around 25uf or even higher, it increases gain yes but also works like a fixed shelving bass control, the smaller the cap the higher the freq of the shelf.
