led/resistor
Started by dolly, August 24, 2006, 08:57:04 AM
dolly
Can someone tell what the correct placement is for an led/resistor. Is it switch/resistor/led or led/resistor/power. ???
Paul Perry (Frostwave)
oldrocker
#2
I'm not sure if this was the question.  Hope this helps.  Make sure the longer lead on the LED goes to plus voltage and the shorter lead goes to negative voltage.
http://www.logmonster.com/images/full/?pic=BAT_LED_1156398401-422-13240.jpg
