messing with the DOD flanger family
Started by runmikeyrun, August 23, 2006, 10:41:09 PM
runmikeyrun
I'm thinking about picking up a used DOD flanger primarily to use with my Total Sonic Annihilation pedal to make uncontrollable noise.  I've got a DOD chorus that i've modded to create some weird warped time delay effects along with some blips and things.  What can i do to the flanger that's a simple yet wacky mod?  I tried some searches but didn't seem to find anything relevant.
Bassist for Foul Spirits
Instagram: @torcheffects
Dislikes: old women
1) Shave the bass from the regen path and set the max regen a LOT higher.
2) Insert a send/return loop in the regen path.
3) Add a momentary switch to add additional capacitance to the clock generator so you can mess with the resampling.
redeffect
Insert a send/return loop in the dry signal path. You know what I'm getting at here...
runmikeyrun
Quote from: redeffect on August 24, 2006, 10:18:54 AM
yeah, that's pretty much what the TSA does.  As for the clock generator, i'm going to have to search the net for some schematics cause i don't know much about modulation effects.  I built a PT80 but it's not even close.  I'll refer back to my chorus mods that should get me in the neighborhood.
Thanks guys!!
Dislikes: old women
