Broken phaser - faulty LFO?
Started by Dave, August 25, 2006, 09:58:16 PM
Dave
I bought a 100% analog Ibanez phaser today, but it doesn't work properly.  When engaged, its definately doing some filtering, but its static.  What could be causing this?  A faulty (stuck?) LFO?  I may be able to return it, but I'd like to fix it if its possible.  Any help would be much appreciated.
Thanks,
Dave
swt
can you tell us what model is it? it's would be simpler to understand, and try to get a schem or a clue at least...
RickL
One possibility is that the wiper of the speed pot is not touching the substrate, either because of a cold solder joint or a faulty pot. I've had a couple of phasers with the exact symptoms you describe that were caused by this problem. Try cleaning the pot first then working from there.
Dave
Quote from: swt on August 25, 2006, 10:13:03 PM
It is an Ibanez PH-99, "Classic Phaser".  I haven't been able to find a schematic for it, but I'll continue looking.
Quote from: RickL on August 25, 2006, 11:06:09 PM
I am a true newbie to pedal construction, how do you go about cleaning the pot?  Its rather small (possibly sealed?), not like the ones I've seen before in instruments.
swt
i have one of those, it's a really great sounding pedal. it has a compressor expander ic (ne571), i think that bad solder is the place to start looking. there's no schem available that i know. it has lots of ics...so don't remember which one is the lfo. beguin resoldering the components from depth and speed pot and following the traces...'til you get to the ic.
  I'd look at and try dating the electros...if not just replace...what year is that thing..?
  But see if I could find a Voltage swinging up/down/up as seen in LFO outputs...with the speed set low.
  Set up a little recorder so you can dictate the voltage readings/part #'s and Pin #'s, on the active components, then listen and copy them on paper.
  Don't overheat the IC's !!!
