Ruby is in Heat
Started by MetalUpYerEye, September 01, 2006, 07:19:30 AM
MetalUpYerEye
Hey guys, I threw together a Ruby for my brother last night and when I fired it up it worked great but the 386 is generating an unusual amount of heat. Like enough to burn your fingers. Enough that I could feel the 3" wide enclosure warm to the touch after about a minute. Any ideas on what could be causing this unusual 386 heat wave?
I also had a question about my Dr. Boogey. I put a fresh battery in it when I boxed it and the next day it was being finnicky so I checked the battery and it was like half dead. I had played it for maybe 2 hours tops, does the Dr. usually eat batteries that fast?
Thanks again guys
Josh
  "Unusual is actually quite "common' and to be expected [I think your ruby works right]. A little chip like this moving enough current to drive a speaker is bound to produce heat byproduct...
  I put a heat dissipation shield on my lm386 that generates all the heat [the first one on my board is a PS divider {?'IIRC]..
  LM386...little chip pouring out current...
  There's not much you can do about this other than turn the volume down or improve the chips ability to dissipate heat.
  I used a 2'' x 2'' copper sheet, marked a chip sized square in the center, then cut lines from the edge to the four corners, bent the 'flaps' I'd created up [so as to allow unrestricted chip install between tall capacitors], I drilled a couple holes in the shield, and used a copper wire to tie the [JB Weld] epoxy-topped chip/heat shield together, for drying...the smashed flat portion of the [solid core] tie wire ends up between the chip and socket.
  There's probably a chip shield available?...@@ny rate, a heat shield allows much more current over the short and long run to flow through the LM386 greatly *Diminished chances for thermal runaway.
MetalUpYerEye
I understand what you're saying, the reason why I said unusual is because I have another Ruby in the same enclosure driving the same speakers and to my knowledge it has never gotten even warm to the touch. Maybe I need to go back and test the old Ruby too, it may be generating the same heat in which case theres probably nothing to worry about.
