Etched Alu
Started by molitovv, August 30, 2006, 10:12:44 PM
darron
Quote from: Meanderthal on September 01, 2006, 02:11:49 PM
Yeah, markm, you certainly know what you're doing!  Those are easily the best looking enclosures I've ever seen(just my opinion, no offence to all the other guys with good looking enclosures!). There's absolutely no doubt that your methods produce outstanding results!
Jeeze- that might sound like boot licking, but those are amazing, especially the English Channel!
english channel was amazing! it's such a good idea...
check out those moollon ones though
Meanderthal
 Yes, the moolon stuff is beautiful, but the pics are so cartoonishly perfect that I got the strong impression that they were photoshopped. Markm's stuff looks so good there's no need to embellish anything- they're the real deal.
Plus, we know that his are etched, but for large scale production engraving with a cnc machine might be much more efficient and produce similar results. That might be what they're doing. I'm sure that if they're milling strats and teles from aluminum they must have cnc machines.
I could be wrong about all of this...
lumpymusic
Seemingly dumb question...I've never used PNP.
Do I laser print/copy NORMALLY on to the blue film
or do I have to INVERT the black/white areas?
ie. When you print black text or artwork on the PNP,
does that end up becoming the ETCHED areas
or the RESIST areas?
Lumpy
Did you do a lot of those Emergency Broadcast Warnings?
Yes. Had it been an actual emergency, I would have had told you.
www.lumpyvoice.net
In Your Ears for 40 Years
www.lumpymusic.com
darron
Quote from: lumpymusic on September 02, 2006, 03:38:58 AM
Lumpy
www.lumpyvoice.net
run it through a laser printer. if you don't have one print with ink and run the print through a laser photocopier.
the area that you print in black will be he resist area. so everywhere with black toner will leave some pnp blue stuck to the metal.
this will mean that you will also need to do a mirror image of your design because you'll be flipping the pnp over.
