question regarding op-amp for Leslie 60 controller clone (help please)
Started by dansamp, August 21, 2006, 11:04:11 AM
dansamp
I just picked up a set of Leslie 60 speakers for my Wurly!
the controller kit is missing
here is the schematic I found online :  www.vintagevibe.com/misc/Leslie%20Speakers%20Console%20Connector%20Kit%207022%20Installation%20Instructions.pdf
  anyway if some one could take a look at the schematic and please let me know what type of op amp I could use for it
the schematic only lists it as a I.C. op-amp
could I use a 4558 ??
also one pot is 500k CCW (is this a reverse log ??)
the other is 100k CW (is this an audio taper pot ??)
your help would be greatly appreciated
Thank You
Dan.....................
The chip is a single op-amp.  The giveaways are as follows (for your future reference):
1) Power goes to pin 7 (that would be 8 on a dual)
2) Output is pin 6
3) there is a small compensating cap (33pf) between pins 1 and 8, which is where compensating caps always go on singles.
I honestly don't know what the original was, so I'm going to wing it and suggest a TL080.  This is a single bifet op-amp that has pins for a compensation cap between 1 and 8.  Specs on the chip are good and it should handle the 4.7M feedback resistance with ease.
Note that this is NOT the same chip as a TL071.
dansamp
dansamp
ok, more help please  :icon_rolleyes:
it seems to be a hard op-amp to locate
where can I find a TL080CPE4 ??? ???
I e-mailed small bear but am waiting on a reply
any suggestions ??
again thank you very much for your help
Dan...............
You can always just skip the 33pf compensating cap and use a TL071.  Sorry.  Should have just said that in the first place.  Didn't know getting a TL080 would be an issue.
dansamp
so if I take out the 33pf cap I can just pop in the other one ???
I was thinking I was going to have to make my own preamp
again thanks Mark
dansamp
ok,
so here's an update for anyone who is interested
I received the opamp from digikey and popped it in and lo and behold it works !!!!!
thank you so much Mark !!!!
now I have to figure out why I only get sound out of one of the channels
I have narrowed it down to the space generator  here is the link to the servie manual : http://www.vintagevibe.com/misc/leslie%20Speaker%20System%20Models%2060_70.pdf
the signal goes into the space generator and gets split into a high and low signal
feeding each speaker powered by it's own amp
so you get stereo chorus/ vibrato I think it ends up being true pitch vibrato
I am not sure how to trace this out since I am not sure what I am looking for
by the way I think it is the same set up that was used in the Fender Rhodes MK V which sounds awesome !!
anyway if any one can help that would be great,.............. Mark ????
dansamp
