Quick FF question for the smart guys
Started by tcobretti, September 19, 2006, 10:28:18 PM
tcobretti
How does the value of the electrolytic cap on the emitter of Q2 affect the sound of the pedal?
aron
Just like any other capacitor in that situation. Smaller values cut more bass.
tcobretti
billings
It's necessary because it gets rid of the negative feedback to the signal from the 1k resistance across the pot at high frequencies.  Take away the negative feedback and you get a large increase in gain, and fuzziness.
aron
As the Geofex article says, if you remove that, then yes, gain is reduced... a lot!
brett
Hi
The value of the cap is made large enough to be effectively zero in comparison to the resistance that it is bypassing.  Larger caps have less impedance to AC.
In the fuzzface, we want the cap resistance to be only a percent or two of 1k (the pot).  That will keep the bypass increasing until the control is nearly maxed.
Using the standard formula (Z (impedance, ohms) = 1/(2.pi.f.C)) we find that for f=440Hz and c=22uF, Z=16 ohms.  That's nice and low compared with the 1k pot, or even the resistance left in the 1k pot when it's at 90% (ie 100 ohms).
The resistance to bass is higher (220Hz = 32 ohms), so in theory the byass of bass tapers off a little as you get to close to maxing the fuzz control.
cheers
Brett Robinson
tcobretti
Quote from: aron on September 19, 2006, 10:47:16 PM
Dammit, I freaking swear that I looked for the answer in RG's article before I posted!  I swear!
