Omni Drive Filter Section - help please.
Started by axeman010, September 21, 2006, 06:34:02 AM
axeman010
Hi All
Another newbie I am afraid !!!!! ::)
Have just built my first pedal and went for the Omni Drive to get to grips with the various elements of distortion pedals.
I have read all the archives about the pedal and have come up with some mods that I intend to try.
However the I could not find anything about the filter section - it does not seem to provide a great change when
engaged - please could somebody tell me how this works and potential mods.
Many thanks !!!
Hanging on in quiet desperation is the english way
SISKO
Hey!. It was my first build some time ago, too.
IIRC, the filter section its a low pass filter. Just that, it adds more bass to your sound.
In my unit, the "filter" was not very noticeable, but i could hear the diference.
Bye
SISKO
--Is there any body out there??--
The octave-up section doubles the frequency of whatever you feed it - in principle - so it is a common strategy to limit the frequency content going into an octave-up fuzz so as to make the octave above the note more noticeable, rather than just crank up ALL harmonic content, regardless of its source.  Because simply distorting a signal will not necesarily change the overall bandwidth of the signal, but just how much more emphasis there is in some parts, often some types of pre-clip toneshaping may not seem to show up.  For instance, I imagine many folks have found that switching pickups or changing the guitar tone control setting does not do very much to their sound when using some distortion pedals.  It sounds a little different, but still sounds every bit as fizzy and fuzzy as before.
So, the filter section will likely have some impact on the performance of the octave-up portion of the Omni-drive, but will not have a huge impact on the performance of the more generic distortion section. In truth, if you wanted to have it play a more "active role, it really should come after the distortion/fuzz section, rather than before the octave section.
