Repairing old Fernandes Sustainer System?
Started by Stolenchild, September 28, 2006, 03:29:56 AM
Stolenchild
Hi there,
hoping not to be off-topic, but as I have seen some of you guys build your own Sustainer circuits it seems to me you have much more knowledge on these things than I.
I once had a Fernandes Neal Schoon guitar with built in sustainer (consisted of 1 SC driver PU - the one with dual blades, and one circuit board which inlcuded the mix/harmonic mode) as I never liked that guitar I tried to build the sustainer system into another guitar - but it never worked very well as I seem to have made some mistakes....
So I thought it would be a good idea to have a working sustainer at hand and I bought an old Fernandes Revival with built in Sustainer - but unfortunately I got ripped off at ebay because first the guitar worked - second day it didn't anymore. So I opened the guitar and what did I see? The wires had been cut everywhere and were just drilled together (without soldering) and some of them had loosened - I can't get the thing to work again - seems like I have again made mistakes in the wiring and worse thing is that this sustainer looked very different because it consists of 2 circuit boards, has no harmonic mode and even the PU looks like a normal Strat PU (with imprinted "Fernandes Sustainer" on it.
I really need help and I now know that I am absolutely incapable of building anything myself. I just want at least one of the guitars to work and I swear I will never touch a soldering bit again.
Stefan
PS: I already asked Fernandes a couple of times on repairs but never got an answer... and it seems that over here in germany nobody has experiences in repairing those electronics
"What's this noisy thing?" - "That's our drummer!"
wordstep
1_go here,take a look,same  as yours?
    http://www.fernandesguitars.com/support.html
2_http://www.fernandesguitars.com/support.html  download th manual,if is the same PCB,
   I think the wire colour can help,if it is the same pcb, solder the wires,you done
3_take some photo of your guitar(inside),find a place on web,put them on,
  I think a lot people want to see.and maybe one of them can help you.
good luck
Stolenchild
Unfortunately my pcb's look different because they are from older models. I guess I make some pics and put them online tonight after work.
But thanx for the links.
wordstep
fenderads  basic wireing,
Fernandes Revival    2 Humberker PICKUP/3 ways switch/one volume/one tone
get  http://fernandesguitars.com/manuals/FSK101.pdf   101 kits manual
goto page 3,you need the PIC(3 way pickup seletor) in the middle as reference
(different pcb,but you need it,print it big,then we talk)
in that PIC. there is a  3 wires--wring clips--[ P/BL/Y ]
Y  ---neck pickup output(from G) go in -->PCB
BL ---the Y signal out of the PCB ---when SUSTAIN off (9 feet switch OFF)
      BL connect to Y (now the sustain off,you can use the guitar 3 way switch
      select different pickup)
P ----the bridge picup go out from the pcb(when sustain on w/harmonics,it come out with             harmonics signal)
[ Y/BL/P ]  all connect to the 9 feet on/off toggle switch 3pdt,
| 1 | 2 | 3 |
| 4 | 5 | 6 |  this is the 9 feet switch
| 7 | 8 | 9 |
  off - on    -- sustain on/off side
lets see,you already see the sustain on/off side
in 4/5/6    Y---4  BL----5   6---empty,coneect nothing
in 1/2/3    P---2   1---bridge pickup out from PCB   3---bridge pickup with harmonics
in 7/8/9    8---- +V   7---give power to sustain pickup   8----give power to sustain driver
this is just a sample,maybe 7/8/9 in the position 4/5/6......
so, use a meter, you can find the 8/6, and find the 4/5/2
I think you can done the others,different pcb doesnt matter.
because the 9 feet on/off switch,use 1/3 to cut off the neck signal when the sustainer
is on. other 2/3 I dont measure,but it will be that way.
I just try to write it down when I still sober,seems my word skill is poor.sorry.
Paul Marossy
Did you ensure that none of the wires are shorting out inside the guitar? That's the very first thing that I would check for.
