Nyquist Aliaser Ring Mod.
Started by Gila_Crisis, October 08, 2006, 04:03:14 AM
Gila_Crisis
hi,
i need some help.
i build this ring mod (more infos here http://www.diystompboxes.com/smfforum/index.php?topic=40860.0, but it doesn't work! the opamp is a tl072 transistor i used bc550 and F245A
what could be?
btw here some pics:
Paul Perry (Frostwave)
>90% of stuff-ups are shorts & pin errors.
But, I'm wondering whether the fet you used is really an equivalent to what is in the original circuit (and if so, whether the pinout is the same).
Personally, when I build something 'weird' from a circuit on the net, and it doesn't work, I try again with the exact components.
At least the circuit is from a reliable source!
Gila_Crisis
the bc550 are equivalent to the 2n5210, i'm sure.
the F245A i'm not! do some one here know an equivalent transistor of 2n5457????
The 2N5457 is equiv to 2SK330, if that helps.
If by F245A you mean BF245A I would have expected that to work (but, I havn't checked the pinouts.)
What country are you in?
Marcos - Munky
I heard that the BF245 is equivalent to the J201/2N5457, but neither me and a friend had lucky using one.
Gila_Crisis
Gila_Crisis
and other opamp equivalnt to tl072? i know the ne5532 is equivalent, but are there others?
http://www.banzaieffects.com/product.php?productid=16537
a European source, but prob just as easy to get it from Steve at Smallbear in USA!
Gila_Crisis
today i checked the circuit with a friend who is electronic eng. and we founded so things that are wrong or look strange. this evening i'm gonna fix them, and maybe hope fully tomorrow the thing is gonna work. maybe...
Coriolis
Well, the TL072 IS NOT equivalent to a 5532!
The TL072 is a fet-input opamp, while the 5532 is bjt-input. The TL072 has much higher input impedance if I not mistaken...
C
Check out some free drum loops and other sounds at my site: http://www.christiancoriolis.com
Gila_Crisis
ops.. sorry... i thought it was so cause i saw moosapotamus used lm5532 in place of tl072...
swt
i'm using bf245a in all circuits that call for fets, and never have a problem...they do have a little different bias though
