Ross Comp w/ SPDT fragment Question??
Started by rosssurf, October 09, 2006, 09:03:12 PM
rosssurf
I have built the layout seen here exactly as shown including the SPDT schematic fragment. http://aronnelson.com/gallery/Toneys-Album/Rossv4
My question is. Of the three toggle positions which one is the stock one? I ask because I like one of the toggle positions much better. It sounds noticeably fuller to me and is the only one I ever use. In my case it happens to be with the toggle all the way to one side ( it is the left position for me but this obviously depends on it's orientation)  I am relatively new at this and even with it open in front of me I can not figure which resistors I am going through in which positions. Can someone tell me which resistor value I am going through based on my description.
In this schem fragment is the middle postition the stock one?
I hope I have asked this question clearly enough to be understood. Sometimes I am not real good at that :icon_redface:
Toney
Hi,
Here's a link to Phillip's Fuzzcentral site where the project, including Mark Hammer's switching mods are eloquently explained.
http://fuzzcentral.tripod.com/compressor.html
post back if you need any clarification.
Cheers, Toney.
bancika
central position is closest to stock. Stock version has 150K resistor, but with this mod in central position we get 150K + 10K = 160K...close enough
