octo booster?
Started by Austin73, October 17, 2006, 04:42:42 AM
Austin73
Anyone built the octo booster on Tcobretti's layouts? Just wondered if it worked and what kind of transformer was used 10k:10k maybe?
Cheers
Aus
Bazz Fuss, Red LLama, Harmonic Jerkulator, LoFo MoFo, NPN Boost, Bronx Cheer, AB Box, Dual Loop, Crash Sync
smnm
tcobretti
I feel I should say that the layout is not verified.   However, I breadboarded the pedal according to the schem and it worked pretty well.
Austin73
Cheers for that the only problem is I live in the UK so can't get that part and also it 1k : 8ohms if i remeber so really struggling. Could I use the tycobra octavia type transformer in it?
Aus
tcobretti
I looked at the RS trasformers specs.  It's wound for an 1k input and an 8 ohm output.  So, I believe that the proper mouser equivalent would be the 42TM013.  I will tell you that I used the RS because I had it on hand; another transformer may work better.
Let me know how this guy works for you!
