Bottom of enclosure
Started by jmdfd415, October 23, 2006, 06:06:23 PM
jmdfd415
What is the black padding stuff on the bottom of enclosures called?  And where do you buy it from?  Some of them have rubber but I am wondering about the stuff on the bottoms of MXR pedals.  Thanks guys!
MikeH
The foam type stuff is neoprene, I think.  I get it at the local craft store for 89 cents a sheet.
jmdfd415
Is one side sticky? Or do you just glue it on?
coffyrock
I'd like to know this too. Also, can you get different colours? might be a cool enclosure covering, glued all over a plastic enclosure??
Built so far: ROG Ruby, matching pair of LPB2s, Mr. Clean, Easy Drive,
Next up: Bazz Fuss, ROG Grace Overdrive, Smashdrive.
shanter
there are two differnt types
with sicky and without.
its like 10 cents more for the sticky. i found it at the local michaels (sp?)
MikeH
Yeah, Michaels is where I found it too.  It comes in many colors.
Meanderthal
jmdfd415
What brand is it that you guys are using?
Barcode80
can't recall the brand right now, but i get it in black (there are many other colors available too) at wal-mart in sheets slightly bigger than copy paper at .48 a sheet. it is great to stick to the bottom of a circuit board to prevent grounds without mounting.
