Which A/B layout to build ?
Started by jeff g, October 20, 2006, 09:17:33 AM
jeff g
I want to build an A/B selector to split my guitar signal through two separate pedal chains to different amps - a 30 W SS and a 5 W tube.
Will this simple Tonepad A/B selector layout work:  http://www.tonepad.com/getFile.asp?id=107  ?
Seljer
Yeah, that'd work fine. I drew up one a while ago too: http://g0g0g0.dyndns.org/uploads/050114/ABbox.gif , some minor difference in the wiring but it does exactly the same thing as the tonepad one.
You would need to get into some slightly more fancy stuff if you want to be able to do A/B/Y
boogietube
There's a great one at www.fulltone.com in the "tech tips & answers" page.
Pedals Built- Morley ABC Box, Fultone A/B Box, DIY Stompboxes True Bypass box, GGG Drop in Wah, AMZ Mosfet Boost, ROG Flipster, ROG Tonemender, Tonepad Big Muff Pi.
On the bench:  Rebote 2.5,  Dr Boogie, TS808
