EH Electric Mistress volume drop problem
Started by screaminking, October 22, 2006, 08:11:31 PM
screaminking
Hey there,
I just found this board a couple of days ago and tried to search through the archives and all that for an answer to my problemand got pretty much nowhere.  I recently picked up an old EH Electic Mistress pedal that needed a bit of fixing.  I took it to my amp tech who followed the schematic and got it all working.  He also modified the pedal to true bypass.  Now that I've got it back from my tech, I notice that there is a volume drop on the pedal when it's engaged.  I found a couple of old threads that discuss this problem, but none of them had an actual solution within them.
If anyone could hook me up with some instructions on how to mod the pedal for a fix, it'd be greatly appreciated it.  From the look of it, it seems like the Electric Mistress pedal is pretty popular.
Thanks.
Bernardduur
Am learning something new every day here
SquareLight | MySpace account
screaminking
The only thread I found with a solution in it basically suggested building an LPB-1 into pedal itself.  Is this really the only option?
screaminking
KB
Hi
If you look at Mark Hammers site
http://hammer.ampage.org
look for device No 5 pdf  -  old electronics mag.  That has some suggestions for modification the Electric Mistress.
Also use the search function here  -  look for Markus' work on a tzf electric mistress there is a  volume drop circuit in the layout which may be of use to you.
Hope this helps
Kevin
screaminking
Thanks a lot.
I'll take a look at those examples.  I appreciate it.
