Treble boosting
Started by Rafa, November 01, 2006, 12:29:34 PM
Rafa
Hi:
I have seen that many amps include a bright switch, so whats the difference of using that switch or increasing the treble from the tonestack??
Which frecuencies are boosted with each??
My amp does not have that switch can I ``simulate´´ it using a signal brightener??
Thanksssss
Rafa
Seljer
Ronsonic
You could simulate it. Or, you could just add a capacitor across your volume control. Typical values run from 220 - 470 pF. Just connect it between the high side of the pot and the wiper. You could even add a switch to make it, uhhh, switchable.
Ron
http://ronbalesfx.blogspot.com
My Blog of FX, Gear and Amp Services and DIY Info
