Help with A/B/y box
Started by kvazr, July 14, 2006, 09:51:54 AM
kvazr
Hello DIY'ers  :)
First off: I'm a completely newbie to DIY - and when I write "newbie" it's litterally true  :icon_biggrin: Bought the Lineal Booster kit from musikding.de long ago and still can't get it to work, that describes how new I am to this.
Anyway! I'm in need of a A/B/y box and decided to pick up the soldering iron again, can't be true that I cannot make my own looper pedal!
I've done a picture of how I want it to work out:
Output A will always be on, no matter what. (That goes to my clean amp)
Output B will be controlled by the switch. (Goes to my distorted amp)
The big question: how am I going to build this? Obviously I cannot read schematics, so if any of you would be kind and helpfull and actually draw the wiring for me, that'll make my day! Can this be done without a PCB or something like that? I don't know how to make such a thing :(
Thanks a lot in advcance!
Edit: I've been searching of course and found a lot of info about loopers, but this seems a bit "special" and different to some of the other looper-questions there's been on this forum :(
/Bo
kvazr
skiraly017
This should work just fine for your needs.
Simple A/B Box
kvazr
Quote from: skiraly017 on July 14, 2006, 04:43:09 PM
Simple A/B Box
Ohh, thanks! That looks fairly simple and easy to build.
However, it dosn't seem to do exactly what I'm looking for. This one, when I step on the switch, I turn off the A loop and turn on the B loop.
The A/B pedal I want to build should have the A loop running all the time and I should be able to turn the B loop on/off when stepping on the switch.
Can the link you gave me be "modified" to my needs written above?
Thanks again!
skiraly017
For $25 you could buy a used Morley A/B/Y box.
funkbass187
hotwire the A output to the jack, and have a switch for the b output. but i think when both are engaged the signal would be cut in half.
"some men see things as they are and ask why... i dream things that never were and ask 'Y NOT'"
antojado
As funkbass said just connect the A jack directly to the input. You'll only need a DPDT switch though since you'll only be switching jack B and the leds.
As skiraly said though you can find a used aby box, that will do what you want, for less than it costs to build one. In fact, I have one for sale on the gear page here: http://thegearpage.net/board/showthread.php?t=152538&highlight=mcboost.
kvazr
Quote from: antojado on July 14, 2006, 06:36:31 PM
Damn, that's cheap  :o Not even worth the hazzle that would be making my own pedal!
I'm going on a one-week vacation in a few hours, so.. Antojado, I'm very interested in your morley pedal, you think you could put a hold on it for me untill I get back home? I'm using paypal myself, so the payment shouldn't be a problem :)
Thanks in advance!
/Bo
antojado
Sure. Contact me when you get back. You can do it through the gear page or ebay as my username is the same there. Have a good vacation.
MadSkillzMan
Ive got a question on the linked schematic,  how are the LED's powered? via 9V not listen or what? by the signal coming in/out?
fixr1984
Quote from: MadSkillzMan on November 06, 2006, 12:47:05 AM
Simple A/B Box
Is this the link you were talking about?  the one in skiraly017's post?  Its powered by the dc jack on the side of the
box in the picture.
