Boss LS-2 Line Selector Question: Blending two sound sources?
Started by Gyoon, November 02, 2006, 02:02:10 PM
Gyoon
Can this be done?  There is no mention of this in the manual.  Baslically, can one soure be plugged into the A return and another into the B return?  Can this be done without having anything plugged into the send jacks?
Glenn
dmk
i think so, but you'd have to have something plugged into the main input for the pedal to turn on...
resistance is futile...
...if <1Ω
zpyder
Quote from: dmk on November 02, 2006, 03:45:57 PM
or you could open it up and hard-wire a short across the ring and sleeve of the input jack.  Then it will always be on if there is a power source
i don't know anything about the specifics of this circuit, but in general shorting the sleeve and ring together on the input jack will tell the unit "something's plugged in - turn on" if the input jack is a stereo jack.  sometimes it is a mono switched jack...  in that case you would just need to short whatever's being switched by the switched jack - probably the gnd connection to the power source
cheers
zpyder
www.mattrabe.com/ultraterrestrial Ultraterrestrial - Just doing our little part to make new rock go where it should have gone in the late-90's, instead of the bullshit you hear on the radio today.
Gyoon
If I plug one source into the main input then one into the A loop input, this would solve it?
Gyoon
Here's what I'm really asking:  Can you plug a sound source into either of the return jacks and have the signal come out the main output?  This is with having nothing plugged into the sends.
Glenn
zpyder
Quote from: Gyoon on November 03, 2006, 08:41:53 PM
why don't you try it?
zpyder
Gyoon
I don't actually have access to one.  There is a store that's willing to bring it in for me, but I would be obligated to purchase it.  There have been a couple that have come up for sale in the local newspapers, but they have both sold before I have had a chance to see them.  I have posted this on another board and they have told me that what I am describing is definitely doable.  There is someone in France that says that the Boss manuals in Europe have a few more pages then the ones in  North America, including schematics!
Glenn
zpyder
Quote from: Gyoon on November 06, 2006, 02:08:12 PM
Okay... then check this out: http://runoffgroove.com/splitter-blend.html
zpyder
