Impedance transformers
Started by zpyder, November 26, 2006, 06:19:22 PM
zpyder
Could I use one of these: http://www.musiciansfriend.com/product/Whirlwind-Little-IMP-Lo-to-Hi-Impedance-Matcher?sku=427600 on BOTH ends of an fx pedal built for guitar/bass in order to use it inline with a microphone and a PA?  IE Will this work:
Balanced Mic -> IMP -> Rebote 2.5 -> IMP -> Balanced PA In
Obviously, one of the IMP's would need to be altered to have an XLR male instead of female... I would likely just rip the IMP's apart, salvage their transofmers, and install them in my stomp box.  Unless I could find a source for the tranformers directly...
I'm trying to get my Rebote 2.5 to work between a mic and the PA (still)... any help would be appreciated!
thanks,
zpyder
www.mattrabe.com/ultraterrestrial Ultraterrestrial - Just doing our little part to make new rock go where it should have gone in the late-90's, instead of the bullshit you hear on the radio today.
rockgardenlove
I think that should work, yes.
You don't need anything on the input into the effect though, do you?  Low to high impedance isn't the problem, high impedance to low is.  So you'd only need one of these on the output of the effect.  What about tacking on a low output impedance output buffer?
