Will it fit!?
Started by Switch, November 28, 2006, 08:29:11 AM
Switch
Ok, so I'm horsing around with a Boss MT-2 metal zone, and I need to put the board for it inside a wah/swell enclosure.
Smallbear has these little puppies http://www.smallbearelec.com/Detail.bok?no=548 which would be awesome, but it's just a question of size. I'll mount the daughterboard with the pots to the side of the chassis somewhere, that shouldn't be a problem, I just can't find the dimensions of the inside of that case. Anyone?
sfr
Looks to be the same enclosure type as Dunlop uses for the Crybaby.   I managed to fit a Neovibe into one of those, and I believe that board is bigger than the ones that Boss uses, although I could be mistaken.
I would email Smallbear and see if they can't get you the info you need, however.
mcasey1
I wanna buy this and put my phase 90 in it!!  I was looking for one, I cant believe I didnt see it on small bear.
