MY FIRST VERO LAYOUT< PRIMITIVE< PLEASE CHECK
Started by mcasey1, December 07, 2006, 12:15:21 AM
mcasey1
Source perfboard layout:
http://runoffgroove.com/multiface.html
Primitive Vero Layout:
Please, if its not trouble, go and see if I made any mistakes, I probably did.  This is my first layout of any kind.
mcasey1
Noticed some pretty glaring errors.  Somewhat revised:
A concern is the 100k in the middle of the board, please check that ones connections.  Bias points are for an externally mounted bias pot.  Q1 left, Q2 right.
Gilles C
The jumper should go to the bottom pin of the left connector, not the middle one.
Gilles
mcasey1
mcasey1
Is there somewhere that has a tutorial on using th layout templates?
mcasey1
choklitlove
my band.                    my DIY page.                    my solo music.
Gilles C
What exactly are the things you would like to learn or know?
How to design a good layout (placement of parts, etc...), or or to make layouts (which program to use, etc...)
Do you want to use a specific program to make the layouts, or draw them by hand?
Etc...
Gilles
