Tonepad's Tremulus Lune question
Started by Pierre, December 09, 2006, 09:49:59 AM
Pierre
Hi !!!
I just finished Tonepad's trem Lune. It works great,without any problems...I have just a little question : Is it normal that the LFO led blinks when the effect is in bypass ?...
Thank you !!!
markm
Quote from: Pierre on December 09, 2006, 09:49:59 AM
Yes.
Quite normal.
However, you can change one thing and have the LED turn off with the circuit.
Disconnect the (-) side of the LED connection and wire that part of the LED to the 3PDT switch.
I don't know if this is an "original" mod of my own 'cause chances are I read it somewhere (probably here!  :icon_smile: ) but,
I do know it worked fine for my Lune build.
Here's a pic;
Pierre
great idea !!!
I love this tremolo, really easy to build, cool sounds and noiseless... :icon_biggrin:
Fp-www.Tonepad.com
And now we got some fancy pcbs available for quick delivery too: silk screen, solder mask, silver pads, RoHS (sorry for the self promotion!).
Fp
www.tonepad.com : Effect PCB Layout artwork classics and originals : www.tonepad.com
DeeBug
Fp,
I'm about to build it with your board.
Will the blinking LED automatically turn off when in bypass after I build it with your board (and Tonepad's recommended offboard wiring)?
Or will I too need to use the mod suggested by markm?  Thanks!
Fp-www.Tonepad.com
You'd have to do what Markm said.
You can also have 2 LEDs, one for bypass and one for LFO speed indication.
