Tim Escobedo Smokey Amp Clone Wiring with mods
Started by __dave, December 10, 2006, 10:25:50 PM
__dave
does this look right? the image in dragonflys layout gallery didn't have the wiring drawn in and i wanted to add the gain pot suggested in another thread.
The spst is supposed to be gain on/off and the 500k pot is supposed to have the 10uF cap in series.
MartyMart
The 10uf cap is across pins 3&1 of the pot, that's parallel
ditch the green wire from pin 8 of the chip, put the 10uf on the strip
right next to pin 8 across three "holes" and cut the middle hole to avoid
shorting it out.
Then take the green wire from far right of the 10uf ( same top strip ) to your
pot lug.... now it's in series :D
To use the pot as a "variable resistor" tie the wiper ( middle ) and one outside
leg together BTW, so now it's two connections and wiper is not "floating"
MM
__dave
Hi, I've revised the wiring, is this what you meant?
MartyMart
Yes, but use an extra "hole" for the 10uf and cut the trace beneath it :
O--cut--O
l          l
l          l
  _____
  l10 ufl
  l cap l
  l       l
  _____
__dave
