fetzer-ruby issues
Started by nag hammadi, December 15, 2006, 04:13:37 AM
nag hammadi
i just finished a ruby-fetzer build from this layout :
http://aronnelson.com/gallery/albums/TheBigMan-Layouts/fetzer_ruby.sized.png
i used a j201, which i thought would be okay.
i am getting signal through to the speakers, but even on a clean setting it is splatting and static-y.  when i turn the trim pot all the way down, it helps, but...
when i turn it up much it just howls...
suggestions?
thanks.
in the face of you all i stand defiant - subhumans
cab42
Try to do a search, as others have experienced the same issues.
I build a Fetzer Ruby on breadboad and it also howled badly. However I never did anything about, I just used the standard input section instead.
Regards
Carsten
"Rick, your work is almost disgusting, it's so beautiful.  Meaning: it's so darned pretty that when I look at my own stuff, it makes me want to puke my guts out."
Ripthorn
nag hammadi
yeah, i just saw to lower the vol pott to 10k.  will do that in the morning.
