rebote for bass...
Started by $uperpuma, December 31, 2006, 03:41:28 PM
$uperpuma
I've built a Rebote Delay For use with bass And have the standard hiss on longer delays. Is there a filter to eliminate the hiss that may not Necessarily be right For guitar but would be ok for bass
Seljer
If you can live with losing a bit more treble in the repeats, you can just increase the values of the capacitors in the low pass filter before the delay http://www.diystompboxes.com/smfforum/index.php?topic=48721.msg362602#msg362602
