First build - help needed debugging
Started by rankine, January 03, 2007, 12:09:37 PM
rankine
I built the Tweako fuzz pedal recently and I had it working but then it stopped. After some fiddling I had it working again but when I went to test it just now it's not working. The pedal works when the effect is bypassed but when the effect is on there is no sound produced.
I used a multimeter to test the voltages at the Collecter, Base and Emitter of the transistor and they all read the same; roughly 3v. I looked on the tweako build instructions and it says I need the voltages as follows;
Collector 2.8 volts
Base 1.5 volts
Emitter .95 volts
Please could someone give me possible reasons why all the voltages are the same? If this helps to pin-point the problem the schematic is here- http://www.smallbearelec.com/Projects/TweakO/TweakO.htm
DryRoasted
First of all welcome to the club!
To help us to help you debug, we have a sort of standard form we use when we post questions like this.  You can see it here http://www.diystompboxes.com/smfforum/index.php?topic=29816.0.  Make another post with 1)=Doesnt work! 2) Name=Tweeko 3) etc etc following the headings shown.  It makes helping a lot easier.  Its a simple circuit so we shouldnt have too much trouble sorting you out.
Have you put the circuit in a case yet?  Are you using perf board or strip board?  Also did you buy a kit of parts from Smallbear or did you buy the parts seperately?  If so what transistor are you using?
cheers,
Jim
Sticking a tube into a tube screamer to get good sound is about like rubbing yourself all over the weight stacks at the gym to get stronger - R.G.
rankine
3) I followed the layout perfectly
It's not in a case yet and I'm using 'pad-per-hole' perf board which was supplied with the kit. I bought it straight from SmallBear so it shouldn't be any component trouble.
DryRoasted
Ok, the next thing to do is check every wire is going to the right place, Its very easy to overlook something and assume its correct, I do it at least once a week.  After the wires if that doesnt clear it up, check that the wires linking each component on the board is not touching somewhere it shouldn't.  With pad per hole is very easy to get a little sliver of solder in the wrong place and short.
good luck
rankine
Thanks, I checked against the layout and I spotted I didn't connect R4 correctly. I now have the correct voltages at each leg of the transistor but I still don't have any sound when the effect is on. Any ideas anyone?
Thanks again
aron
OK, start looking at your wiring from the jacks to the switch to board.
rankine
 :) I've sorted it now. It was connection to one of the switch terminals which turns the effect on and off.
Thanks for the help I've learnt alot from this.
8mileshigh
Rakine,
I use a dab of flux when soldering wire to switches and jacks.  I built the Tweako as well, it's a rewarding first built.
Chris
Builts completed: Tweak-O, Fuzz Face Si and Ge, Rangemaster,Fuzzrite Si & Ge, Bazz Fuzz, L'il Devil Fuzz, Bosstone one knober, Bosstone Sustainer, Cream Pie, Kay Fuzztone. http://www.myspace.com/chrisdarlington
