need help finding a pot
Started by pfindeis, January 06, 2007, 03:52:43 PM
pfindeis
I bought a used digitech gnx300. it arrived with a broken volume pot for the 1/4" output jacks. when i plug into those jacks i get real nasty static noise combined with the guitar.
I found it does work fine with the headphone jack.
I would like to replace the bad pot. It's marked B20K on the top of the broken piece.
Where do i get a 20k pot ? And do i get audio taper?  I know alot of companys have minimum orders.
The Tone God
I think it might be an Alps 9mm trimpot. Many 9mm trimpots are audio taper. 20K should not be a tough value to find. Check Mouser.
Andrew
Ronsonic
Call Digitech and order one.
The "B" in the name is the taper.
Ron
http://ronbalesfx.blogspot.com
My Blog of FX, Gear and Amp Services and DIY Info
pfindeis
Quote from: Ronsonic on January 06, 2007, 05:07:23 PM
Ron
Got Digitech's parts dept number? I can't seem to find one.
The "B" in the name is the taper. That tells me alot. Is B audio or linear?
dxm1
Quote from: pfindeis on January 06, 2007, 06:46:05 PM
A = Audio
B = Linear
C (or F) = Reverse Log
GibsonGM
Digitech has a parts department, and you can order online...I just did about a month ago.  They have all the parts (jacks, pots, switches) for their products there.  Search online, Google "Digitech parts" or something. Right off of their homepage (I think the link is Store or something).  Good luck!
pfindeis
Quote from: GibsonGM on January 06, 2007, 11:50:43 PM
I found the online Digitech store and they list some pots but none specifically for the gnx3000.
I guess i'll try to call.
Thanks for all your help,
Pete
Processaurus
Quote from: The Tone God on January 06, 2007, 04:13:29 PM
Andrew
Hmm, I think those look just like the 9mm Alpha PCB mount pots I've gotten before from mouser.
