Ruby Question...Help debugging
Started by modsquad, January 14, 2007, 04:28:36 PM
modsquad
I built a Ruby and I am getting no sound from the speaker except when I plug into the input jack I get a popping sound.  I think the voltages are correct:
LM386:
1  1.35
2-4 0
5  3.68
6  9.14
7  4.61
8  1.34
MPF102
G  0
S  1.51
D  9.09
I am using a 1w 4 ohm speaker with the positive of speaker connected to negative of 220uf cap and the negative of the speaker to ground.  Tip of jack to G of MPF102, Ring to negative of battery and sleeve to ground.
"Chuck Norris sleeps with a night light, not because he is afraid of the dark but because the dark is afraid of him"
modsquad
  Your guitar is turned up? Sounds like a possible lack of input...
  I forget the 386 pinout
1  1.35 [I forget
2-4 0 [''   ''
5  3.68 [''  ''
6  9.14   [output IIRC, looks like the highest voltage here [V+?
7  4.61  [isn't this the Vin/V+ pin ? should be the highest voltage if...
8  1.34  [IIRC pins 1 and 8 are N/C,
   Pin 4 is ground?
and don't have the schematic memorized.
southtown
southtown
Quote from: petemoore on January 15, 2007, 12:15:51 PM
obviously  ;)
modsquad
Is that like is your PC on and have you tried rebooting  ;D
Actually I swapped cords out and guitars to no avail.
modsquad
Still have no sound, the only thing I did differently was combine two resistors in series for 1.6M instead of 1.5M.  Could that cause a drop in input?
