How do I add a LED to my DOD YJM308 Preamp Overdrive (without a DPDT or 3PDT)???
Started by ianvomsaal, August 14, 2006, 10:34:14 PM
ianvomsaal
Hi all - I haven't been able to find an answer to this question anywhere???
I have a DOD YJM308 Preamp Overdrive, and I'd like to add a LED to this pedal (since it doesn't have one - I have no idea why it wasn't made with one).
I believe it uses a CARLING "SPDT" switch, NOT a DPDT or 3PDT switch.
I have a switch for a malfunctioning CRYBABY that looks just like the one used in this DOD YJM308, so I'm assuming it's the same kind of switch (there's only 3 posts on this switch - 1 on the left and 2 on the right).
Is there any way to add an on/off LED to this DOD pedal without getting a different kind of switch???  Can this be done???  If so, can anyone please tell me how.
Thank you all sooo much for your time, it's much appreciated . . .
   -  Ian
click here: FOR MY BACKGROUND and TO LISTEN TO SOME OF MY MUSIC
~ Music-washes-away-the-dust-of-everyday-life ~ ART BLAKEY
~ Without-music-life-would-be-a-mistake ~ FRIEDRICH NIETZSCHE
aron
The easiest way is to use a 3PDT switch. The second easiest way is to use a millenium bypass with a DPDT. Check out the FAQ - it explains this.
http://www.diystompboxes.com/cnews/FAQ.html
So no, you need another type of switch I believe. (Unless your pedal uses another type of switching - which is doubtful)
lookie here
yeah I am using the Millenium Bypass too. i would imagine it would be cheaper than buying a 3dpt switch
Renegades Of Funk
wampcat1
Quote from: lookie here on August 16, 2006, 06:59:02 PM
Cheaper, I don't believe so -- Aron sells the 3pdt switches for $6 or somewhere around there. Depending on your experience level, you may want to just use the 3pdt to eliminate any extra hassle. :)
bw
user
Just use a simple DPDT switch and do that Untrue Bypassing with Led thing. :D
