Stage Center Reverb
Started by ranchak, February 07, 2007, 10:37:36 PM
ranchak
I built the Stage Center Reverb from the GGG site. I used a reverb tank that I had. It's a 3 spring, long tank unit. The input ohms is around 250. The GGG site recommends a tank with 310 ohm input, but I couldn't find one. The thing that I noticed is that reverb is not that great, it's either very dark or overpowering. Has anybody else experienced this. Any suggestions?
Quackzed
use a smaller wet out cap and cut some of the reverbs low end? might clean it up...
  Me too
  I used an Accutronics med length.
  That might load the output of the driver, IIRC something about using an LM386 stage to drive a smaller ohmage.
  I said sounds great..has two knobs, on is mix, the other is gain on the driver IIRC, and that pot has a small sweet zone for the driver level which needs fairly careful setting to drive the springs 'enough' to reverberate 'em without overdriving them.
  The first thing I'd think is about the ohmage mismatch, that could easily fit your description and be loading down the driver output.
