Problem with led trick.
Started by jpm83, January 26, 2007, 03:26:17 PM
jpm83
The problem is that my led trick by analog alchemy is burning led, all the wires are in right place and led is oriented right.
Janne
Papa_lazerous
I dont know what you LED trick is.......
But if your LED is burning out you are putting more than current than its happy with through it END OF!
jpm83
Thanks for answering. Maybe I should try millennium bypass.
Janne
southtown
do you mean your indicator led? are you putting a resistor in series with it?
zencafe
If you're using a 3PDT switch... have you connected a pull-up resistor? If you haven't... that's the reason why you're burning your LEDs... just in case, I use a 4.7k resistor, and it works perfectly.
D.
Long Life to Cmos
Barcode80
effects connection (http://www.effectsconnection.com/oscommerce/) also sells LEDs with resistor included for pretty cheap.
