output impedence
Started by squidsquad, January 27, 2007, 10:12:59 PM
squidsquad
If I run a Fuzz Face into Jack's minibooster...will I get a low impedence output?
(To feed my Memory Man)
I've noticed the MM doesn't like an FF feeding it (echoes get weak).
It does seem to work well w/a Jordon Bosstone...but I'd like a different sound.
(I'd try it...but all my FF's are junked because of the problem)
amz-fx
The mini-booster isn't right for this application unless you want to add some distortion from it as well since it has a lot of gain. Also it doesn't have much drive capability so it's not good as a buffer...  which is why the pc boards that I sell have the option to make a buffered version included...
regards, Jack
