Bazz Fuss + Buzz Box
Started by JonFrum, January 31, 2007, 08:00:05 PM
JonFrum
I've been planning on building a Bazz Fuss in my next set of projects, and I just had the idea to make it a Buzz Box, and interrupt the circuit to make it selectable - Bazz Fuss or Buzz Box. Would I just cut the circuit after the first output blocking cap and run it to a switch and back?
The Buzz Box is at the bottom of the page:
http://www.home-wrecker.com/bazz.html
tcobretti
Yes, but you may want to play with the cap values, and you will almost certainly want to use a higher HFE transistor for Q1.
I could never get a true octave out of the buzz box; it sounded like an octave fuzz with no octave.
