It may have potential
Started by Tomass_17, February 01, 2007, 02:00:13 AM
Tomass_17
I've got this old combo amp, it was just a cheapie and now has a blown speaker. So its sitting around doing nothing at the moment, but opening it up and peering inside i was thinking that I could rip all the guts out of it and use the transformer and the shell of the amp for a all tube bass amp. Aside from electrical hazard, can i use the transformer that it has on it now?
Meanderthal
 No. That is not an output transformer, it's a power transformer, and chances are pretty slim that it puts out the kind of voltage you need for a tube amp.
If the amp still works, why not build a nifty enclosure for it and make a SS head out of it?  Should be ok for a beater...
Tomass_17
ah ok, that make sense. Shouldve realised that, the amp it self was nothing fancy so i wont worry about that. Thanks for the info anyway
Unclerny
these type chassis are not very sturdy for tube amps to begin with.  Then you'd have to deal with the numerous holes you won't need.
and lastly that xmer won't work for anything in a tube amp.
UE
Uncle Ernie's Effects
One Man's Distortion is Another Man's Reality
