old diode and tran checker...EZ Leakage test???
Started by m_charles, February 12, 2007, 09:37:23 PM
m_charles
Is this an easy way to check leakage on a geranium trannie (assuming it works)?
Also an easy way to check gain?
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=290082677879&ssPageName=Action:MPS
Thanks,
Chuck
No, but this one is:
http://cgi.ebay.com/Sencore-TF46-Super-Cricket-Transistor-FET-Tester-NR_W0QQitemZ260085229191QQihZ016QQcategoryZ1504QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
The Super Cricket in the right hands will do everything but MAKE germanium transistors.
I would not part with mine; $34 is a real, true bargain if it works.
m_charles
what will this do then RG???
as opposed to yours...
m_charles
just wanted to bump to see if you're still around RG...
This one looks like it has much the same capability as my germanium leakage tester, but boxed up with its own meter and switches.
The Cricket will do much more - including checking FETs.
m_charles
zachomega
Makes me really wish I had the manual for my Sencore TF17.
-Zach Omega
