Can anyone tell me what value pots these are?
Started by Duggyrocks, February 11, 2007, 10:40:00 AM
Duggyrocks
I have a dano fab OD, and before I butcher it, I want to find out will te pots be usful. The gain pot says "C502", and the tone level pots say "B503". Anyone know what value these are?
strangerock
KerryF
Quote from: strangerock on February 11, 2007, 10:56:42 AM
i think 502 is 500k and 503 is 50k.
sr
I think so also.  The one with the C is reverse taper.  The one with the B is linear taper.
markm
oldschoolanalog
502=50 w/2 zeros=5000=5k
503=50 w/3 zeros=50000=50k
Mystery lounge. No tables, chairs or waiters here. In fact, we're all quite alone.
KerryF
Hanglow
yup, when they are numbered like that its like cap numbering - the third number is the multiplier
Although I only worked that out after I had tested about fifteen trim pots that I had butchered off an old vcr  to see what values they were  >:( I was a little slow with that)  ;D
  The DMM is pot friendly to a point, it'll tell you the pot value, and whether or not it is linear...ie with shaft center positioned, close to equal resistances from the wiper to each outside lug.
